Stryofoam Vs. Blue Or Pink Foam Boards. - Insulation - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 10:15 AM   #1
Rewards Points: 163
Stryofoam vs. Blue or Pink foam boards.
Is there much difference between the 3 styles, regular white styrofoam vs the dow pink foam board, or the blue foam board?
There's a guy selling used white styrofoam by me for $2 a 4X8 sheet, and I'm thinking that might be the way to go for insulating by basement.
52Caddy is offline   Reply With Quote
Old 03-20-2011, 11:31 PM   #2
Registered User
Rewards Points: 526
That is a really good price. 6th para; http://www.buildingscience.com/docum...ent-insulation
Gary
Old 03-21-2011, 09:13 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
What is the thickness? Generally XPS (blue or pink) will offer superior performance, but it will be hard to beat that price. GBR has a good link there.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-21-2011, 11:37 AM   #4
I can tie my own shoes
algored2deth's Avatar
Read this as well
http://www.finehomebuilding.com/item...hould-i-choose
Avoid the white styrofoam for basement. It will wick moisture.
algored2deth is offline   Reply With Quote
i would like to remove old insulation from attic and start over with blue jean insulation in attic. My brother thinks this is a waste of time. I plan on pulling up old original boards and putting down new blue jean insulation followed by new plywoo waverunner Flooring 2 02-27-2011 07:07 PM
Polyisocyanurate Rigid Foam Insulation Boards Over Plywood Sheathing & Vapor Barriers cloves Building & Construction 10 12-05-2010 11:31 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Covering basement windows with Blue Foam Board gregzoll Building & Construction 2 08-25-2010 09:49 PM
