Steel Studs Over XPS In Basement - Insulation - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 06:35 PM   #1
Steel studs over XPS in basement
Hey guys and gals, I am new to this site but not to construction. All of my work is commercial or industrial so I tend to do projects at my home in that manner. I have a 1500 sqft basement I am finishing. I plan to use 2"xps glued to the masonry (CMU and poured walls) followed with 1 5/8 inch steel studs whenever possible with 3 1/2inch wet walls. Drywall will be 5/8 inch. No other insulation except in the rim joist. I live in Alabama on lever with Atlanta and Birmingham. Ceiling will be 2 x 2 layin. Floor undecided at this time.
Any of you tried this method? May seem odd if you are accustomed to driving nails, but its very typical of what I do.
Thanks for your help.
Fnsane
fnsane is offline   Reply With Quote
Old 02-23-2012, 06:45 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,040
Rigid foam on block/concrete is a pretty well accepted method for basement insulation systems.
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
Steel Studs? Quikstix anyone heard of them? D270 Building & Construction 0 04-02-2011 08:27 PM
Steel Studs and Sheetrock slamseven Drywall & Plaster 6 03-15-2011 09:53 PM
Basement Steel studs gauge/width? bergerdude Building & Construction 2 03-03-2010 03:27 PM
Steel studs / Basement Insulation Chemist1961 Building & Construction 9 06-26-2009 01:54 PM
