Spray Foam Question - Insulation - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 12:10 PM   #1
Rewards Points: 103
Spray foam question
Guys, question for you all. I am in the process of finishing our basement, framing is complete. I was going to spray foam the walls which are concrete slab 10 inches thick. We have several cracks in the walls which have all been epoxied plugged. My question is with future moisture. If a foundation crack would possibly form behind the foam how would we ever be able to locate it? Does the foam seal the wall as to prevent little cracks from leaking? Would it be better to just use regular fiberglass insulation? Thanks in advance for any help that you could provide. Mike
Mlorek is offline   Reply With Quote
Old 03-28-2013, 02:42 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,994
Open cell foam will allow it to perk through.
Closed cell foam will be tough to track backwards as it is moisture impermeable so it could show up a ways away from where it started.
Spray foam and ground wire. bf514921 Electrical 4 07-13-2012 06:35 AM
highest R-value spray foam MLMIB Insulation 12 02-16-2012 03:33 PM
Diy spray foam insualtion kits ?? What have I done Building & Construction 3 12-14-2009 09:20 AM
Touch n' Foam (spray) 'Pro System' - good product? KatieAK Building & Construction 0 11-19-2009 07:59 PM
Closed Cell Spray Foam with Fiberglass? ddave23 Building & Construction 1 10-28-2009 02:54 PM
