#1 |
Spray Foam Question
I would like to know your opinions on spray foam around my rim joist. I was looking at getting this product
http://www.sprayfoamdirect.com/produ...oam-kit-detail to seal it up and then using FG or Cellulose afterwards or just leave it foamed? Does this sound ok? TIA |
#2 |
Exterior Construction
Spray Foam Question
Pretty good.
Wouldn't really worry about the anti-microbial part of it to be honest. CC SPF is perfect for rim joists. Put on about 2" and then cover it with Roxul and you are golden.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Spray Foam Question |
| Display Modes | |
| Spray foam the interior of a exterior brick wall? | Convict3 | Insulation | 13 | 08-21-2012 08:01 AM |
| Is spray foam insulation that much better than fiberglass? | HautingLu | General Discussion | 18 | 09-21-2010 07:36 PM |
| DIY spray foam kits | HitLines | Building & Construction | 4 | 03-18-2010 01:58 AM |
| Insulating with spray foam and caulking | willowgirl | Building & Construction | 71 | 01-09-2010 09:42 AM |
| Touch n' Foam (spray) 'Pro System' - good product? | KatieAK | Building & Construction | 0 | 11-19-2009 07:59 PM |
