Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-20-2012, 03:43 AM   #1
spray foam question
I'am getting ready to redo the drywall in my living room.The question I have is I want to get a DIY spray foam (close cell). Is it okay to use 2" foam board the high density kind and then fell the rest with foam, or should I just fill the hole cavity with the foam.Thought if I did it the foam board way I could save a little money. I have 2 outside walls and a ceiling that need to be done
bignezzy74 is offline   Reply With Quote
Old 08-20-2012, 08:14 AM   #2
Exterior Construction
Windows on Wash's Avatar
spray foam question
Are you putting the foam board on the outside wall?
If so, typical fiber insulation is just fine inside the walls at that point.
Spray foam the interior of a exterior brick wall? Convict3 Insulation 13 08-21-2012 08:01 AM
stone coated steel and spray foam insulation waternut Roofing 2 01-15-2011 07:36 PM
Tiger Spray Foam BlueBSH Building & Construction 0 05-18-2010 03:26 PM
Touch n' Foam (spray) 'Pro System' - good product? KatieAK Building & Construction 0 11-19-2009 07:59 PM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 03:48 PM
