-   Insulation (http://www.diychatroom.com/f103/)
-   -   Spray foam the interior of a exterior brick wall? (http://www.diychatroom.com/f103/spray-foam-interior-exterior-brick-wall-154073/)
Convict3 08-18-2012 04:33 AM
I have,a 1977 single story all brick house im south texas I need to strip to the studs so I can rewire and replumb. Im new to the idea of spray foam but want to get it installed. the house has a brick pocket with weep holes, soffet and ridgecap. I wanted to add flooring to the attic for storage and have a surface to spray foam the ceiling below. If there is no vapor barrier in the wall do I spray the brick? Or put xps im each stud bay then foam that? Also I wanted to the leave the soffet and ridge cap open for ventalation, but seal the walls and ceiling of the house. Will this cause any issues?
Windows on Wash 08-18-2012 01:03 PM
You don't spray the bring in this case.
Brick is very likely a brick veneer wall and is designed to be vented/breathable.
Air barrier is on the wall on the outside surface of the studs. That is where you vapor control layer should be as well.
Convict3 08-18-2012 10:52 PM
Demo will start at the end of october. But I couldn t wait so I removed a non working receptical and box. Through the box hole i can see brick and a weep hole. So either the gypson board rotted away or there was never a vapor barrier. Not even tar paper. So when the time comes do I seal the the far side of the wall with foam board and spray 3 inches of 3lbs closed cell foam im the stud bay. Leaving the brickpocket intact.
Does anyone have a picture of how this should look.
Windows on Wash 08-19-2012 08:29 AM
If you can get rigid foam to the outside wall, make sure it is the proper vapor permeance for your region.
I think 3" of ccSPF at that point is overkill.
http://www.buildingscience.com/resou..._code_changes/
Msradell 08-19-2012 04:24 PM
Another thing you may want to consider is to insulate the bottom of the roof instead of the top of the ceiling. This is called "Hot Deck" and has been proven to be a very effective method that doesn't affect the life of shingles. One big advantage is that it makes future modifications much easier. If you do that either not have to worry about ventilation of the attic area as it becomes part of the conditioned space.
Gary in WA 08-20-2012 12:56 AM
"If there is no vapor barrier in the wall do I spray the brick?"---- no, don't spray directly on the brick, as WoW said. Can you work some fanfold on the studs (to protect them from solar-driven moisture on the sunny-side), yet still leave an air channel for the brick? Then add the cavity XPS, canned foamed at all edges= air-tight. ADA the drywall.
Expect 10% less shingle life with a closed roof. http://www.buildingscience.com/docum...ion/#Cash_2005
If HVAC and ducts are in the attic, closed roof is good....if not, leave it vented.
Gary
Convict3 08-20-2012 02:35 AM
The ducts are in the attic but if I seal it the gas heat will not get enough combustion air. I cant afford a ac overhaul atm. The roof is 7 years old . What type if canned foam should I use to air.seal the xps?
Windows on Wash 08-20-2012 08:13 AM
Very unlikely the sealed attic will starve the unit for combustion air but if you are concerned, test the draft on it.
A closed cell can foam is a good idea. I like the window and door specific stuff as it lays down a more representative bead and does not have any pull back issues.
Convict3 08-20-2012 12:58 PM
I calL a sf contractor today and he recomended going to unvented route by spraying the brick,sealing the soffet and ridge cap. With 3in. 3lbs closed cell on walls and 5 in. on the roof. All for 8k. Does this sound right.
Msradell 08-20-2012 04:57 PM
That doesn't sound like a bad price, what is the "R" he's telling you you will achieve with that? Foam from different manufacturers has different "R" values.
Windows on Wash 08-20-2012 05:21 PM
Where is the home?
That will dictate what is code compliant on the roof.
Convict3 08-20-2012 09:14 PM
They are claiming r7 per inch bayseal brand closed cell
Convict3 08-20-2012 09:16 PM
Originally Posted by Windows on Wash (Post 992869)
Where is the home?
South texas
Windows on Wash 08-21-2012 08:01 AM
Claimed R-Values are different than realized in most cases.
I would count on R-6 per inch and that is a more reasonable expectation.
R-30 should be fine at that point but where is Gary GBR when you need him...:laughing:
http://publicecodes.cyberregs.com/ic..._11_sec002.htm
