Spray Foam Insulation Odor - Insulation - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 12:45 PM   #1
Rewards Points: 107
Spray foam insulation odor
This past Monday, we had the rim joists in our basement sealed with spray foam insulation. They also added some blown in insulation in the attic. The spray foam is "open cell" spray foam and the attic insulation is borate based cellulose insulation.
The odor, we presume is from the spray foam, has diminished, but not yet gone away. It is lessening. We are running fans and trying to keept he air moving. Should I be concerned that the smell is still there? I broke off a piece of the foam that was sprayed on an area that is not exposed to the outside and held it to my nose and there was no odor. Any ideas?
Also, they originally were going to pump in the cellulose over our kitchen ceiling as we can feel a lot of air from the can lights we had installed when we did our addition. FOr logistical reasons, they could not get in there. However, they did suggest replaceing the cans with air-sealed cans. Any ideas if this works? IF so, any brands to use or stay away from?
Thankls
Ranger1227 is offline   Reply With Quote
Old 02-11-2012, 09:34 PM   #2
Rewards Points: 14,306
It should have been IC Air Tite cans.
I've used three differant brands and they all worked out fine.
Old 02-12-2012, 07:43 AM   #3
Rewards Points: 107
air tight cans
The addition was done in 2003. Did they have air tite cans then? the cnas are IC rated, though.
Old 02-12-2012, 07:44 AM   #4
Rewards Points: 107
Replacement trims
Can I simply replace the trims with air tite trims? I saw that HD have them. I though about giving that a try.
Old 02-13-2012, 11:29 PM   #5
Here is something from the health department from the state I live in about foam it has some info on the smell
http://www.ct.gov/dph/lib/dph/enviro..._brief_spf.pdf
parts is offline   Reply With Quote
Old 02-13-2012, 11:37 PM   #6
Air tite cans have a safety device that shuts the light off if it over heats.
Do not use a differant trim ring.
Old 02-14-2012, 11:53 AM   #7
Rewards Points: 1,092
Parts: Thanks for that link.
Odd odor from insulation GARoss Insulation 7 03-11-2014 12:10 AM
Vapor sealing with open cell foam insulation PerpetuallyRepairing Insulation 6 12-17-2011 09:16 PM
stone coated steel and spray foam insulation waternut Roofing/Siding 2 01-15-2011 06:36 PM
DIY 2 Part Spray foam Insulation kphares Building & Construction 1 01-10-2011 02:53 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
