Spray Foam Insulation Depth - 2" Vs. 3" ? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-23-2014, 08:13 PM   #1
Rewards Points: 93
Spray foam insulation depth - 2" vs. 3" ?
We're well into a major basement renovation project that involved jacking the house up and building foundation walls under some ground floor additions built by a previous owner on concrete posts (i.e. there was just a crawlspace underneath).
The contract includes polyurethane spray foam insulation to a depth of 3" on all exterior foundation walls, end joists etc. The drywall went up before the holidays, but I ended up taking it back down due to some unsatisfactory work that's discussed in this thread.
After taking down the walls, it seemed hard to believe that the spray foam could be 3" thick. I took a very thin, sharp probe, and and poked about ten random holes through the foam to the concrete, and found that virtually every one was to a depth of about 2". I marked the holes, and could plug them if this is an issue.
I'm interested in getting informed opinions on whether this is a big enough deal to take up with the contractor. I don't know if there's some kind of "normal tolerance" by which 2" is ok, or if they really haven't followed the manufacturer's directions and I'm getting ripped off getting less than I paid for.
Thanks for any comments,
P
Proton is offline   Reply With Quote
Old 01-23-2014, 08:45 PM   #2
P, I asked for and paid for 2" and that's what I got as a minimum. In some places its considerably thicker. They used a thin pick to judge the depth as they sprayed. I believe 2" was all they could put during a single application, due to the heat and curing process. They would have had to do another pass to get to 3", if I recall correctly.
It was billed out at so much per square foot, then x2 for the thickness.
If you paid for 3", you should have gotten 3" as a minimum. I don't believe there is appreciable "shrinkage" of applied product.
You should plug those holes.
Mike.
northernlite is offline   Reply With Quote
The Following 2 Users Say Thank You to northernlite For This Useful Post:
Gary in WA (01-23-2014), Windows on Wash (01-23-2014)
Old 01-23-2014, 09:52 PM   #3
Rewards Points: 93
Mike.
Thanks Mike - I will mention to contractor, and ask for a credit. Most of the other walls are up so he can't really apply more (I just found this because he did a horrible job on this drywall and I took it down because this room is to have soundproofing treatment).
What do you recommend to plug the holes?
P
Old 01-23-2014, 10:00 PM   #4
Where you are, the 2" will be acting as a vapor barrier. The goal will be to maintain the airtight integrity of that barrier. I would use a caulking or spray foam from a can.
I have one of those screw-on applicators so I can pinpoint apply and control it and re-use the cannister. If you have a number of locations to use foam, it's worth the investment. If not, 6-7 bucks for the single use can will do the trick. Fill the cavity with roxul, then your RC as per instructions, and drywall away.
The Following User Says Thank You to northernlite For This Useful Post:
Proton (01-23-2014)
Spray foam insulation to prevent condensation? (1st post) ajmckay Plumbing 3 08-29-2012 11:45 AM
rim-joist insulation - spray or sheet foam? redline9k Insulation 19 01-30-2012 09:44 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
conflicting spray foam insulation warnings yogi Building & Construction 8 10-01-2009 11:24 PM
spray foam insulation jdgeorge Building & Construction 2 03-24-2009 06:15 PM
