Spray foam inside metal door
Theoretically...yes.
Would it be a PITB and possible damage the door, also yes.
You could drop a really long hose to the bottom of the door and spray from bottom up but the concern is that you bridge a location and the foam over pressurizes (largely because you will be putting so much down) and messes up the door.
You may have an issue with the curing of the foam as well because you will be putting so much in and there will be little moisture/air to cure up.
