Spray Foam Or Cellulose In Attic - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-27-2014, 02:46 PM   #16
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
This is the stuff we used
http://www.industrialinsulation.com/...spray_foam.htm
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 08-27-2014, 03:15 PM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,744
Doing it in the winter it definitely will lose some heat and you'll have a poor yield on the tanks.
Big props to you for doing it. What sort of reductions in utilities and comfort improvements have you noted since doing the air sealing?
Old 08-27-2014, 03:48 PM   #18
mnp13's Avatar
Rewards Points: 512
We had a 30 year old boiler that was failing so our utilities were really high regardless. We replaced the boiler in November, 2013 (original install was November 1983) and then had the never-ending-winter. So that was expensive too!
There was a definite improvement in comfort though. The upstairs felt a lot warmer overall and the bedrooms were a lot more comfortable overall.
Michelle
Insulating an Attic - Spray Foam in the Rafters v. Cellulose on the Floor esteve999 Insulation 5 12-13-2014 10:29 AM
Spray foam the interior of a exterior brick wall? Convict3 Insulation 13 08-21-2012 07:01 AM
Attic Insulation: Should I use fiberglass or cellulose? strategery Insulation 20 11-14-2011 11:10 AM
Master Bedroom very warm ks-man HVAC 34 11-03-2011 09:42 PM
Spray Foam Installation Problems Ron6519 Building & Construction 7 07-11-2011 01:50 PM
