Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-31-2013, 03:09 PM   #1
spray foam behind drywall?
Is it possible to spray foam in a finished wall? Say by cutting a hole in the top of the drywall and spraying down? Or do I need to take all the drywall down? Or would another option be better (blown in insulation)?
I have 2 rooms that have crappy old insulation that I can pull out from the basement and wanna re insulate.
listo is offline   Reply With Quote
Old 01-31-2013, 03:20 PM   #2
Windows & Remodeling
HomeSealed's Avatar
There are ways to do that, although dense packed cellulose would be far more cost-effective. If budget is not a concern, spray foam is great.
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
listo (02-03-2013)
Old 01-31-2013, 04:06 PM   #3
What type siding do you have? More often it's done from the outside.
It's not the best way to do it but better then nothing.
There working blind so there's going to be all kinds of way to have gaps behind that wall.
listo (02-03-2013)
Old 01-31-2013, 06:44 PM   #4
747
registered
747's Avatar
Yes for a 100 percent fact. I seen it done on hgtv.
747 is online now   Reply With Quote
Old 02-02-2013, 04:59 PM   #5
Moderator
Either way, I'd fire-block the stud walls (upper ceiling level) from the basement ...
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
listo (02-03-2013)
highest R-value spray foam MLMIB Insulation 12 02-16-2012 03:33 PM
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 12:53 PM
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 04:07 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 01:58 AM
Attaching Drywall to 4" of Rigid Foam PerpetuallyRepairing Drywall & Plaster 9 02-19-2009 06:24 PM
