Spray Foam! - Insulation - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 09:02 AM   #1
Spray foam!
I am wondering if spray foam can act as an insulation and vapor barrier on a cement foundation basement wall...any advice...
stoked91 is offline   Reply With Quote
Old 04-08-2012, 09:34 AM   #2
Rewards Points: 168
i believe it can. but wait around for someone who knows for sure.
Fix'n it is offline   Reply With Quote
Old 04-08-2012, 12:41 PM   #3
Rewards Points: 512
theres rated spray foams that act as a insulation and a vapour barrier. if you are using a can like great stuff it is not a rated vapour barrier spray foam.
princelake is offline   Reply With Quote
Old 04-08-2012, 01:31 PM   #4
Rewards Points: 1,092
both open and closed cell are insulators. open cell is much more vapor open, and is usually painted w/ a vapor retarder paint if a vapor retarder is needed.
Old 04-09-2012, 07:57 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 932
Depending on applied thickness and foam type, yes.
Closed cell, as jklingel said, is not vapor open and at sufficient applied depths, does qualify as a vapor barrier.
You don't really need to thick of a vapor barrier on concrete as much as you need to thick of condensation resistance and an air barrier.
Spray foam insulation troyce1 Insulation 12 12-14-2014 07:30 AM
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 12:53 PM
using XPS and spray foam together in stud bay diybrad Building & Construction 5 08-06-2011 09:08 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
