Soundproofing An Existing Interior Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 09:48 AM   #1
Soundproofing an Existing Interior Wall
Is there anything on the market a DIYer can use to soundproof an existing interior wall between a bedroom and a bathroom to decrease the sound coming through?
Peanut11 is offline   Reply With Quote
Old 09-12-2012, 10:08 AM   #2
Soundproofing Guy
Rewards Points: 158
Do you know what your stud material is? Stud spacing?
Ted White is offline   Reply With Quote
Old 09-12-2012, 04:04 PM   #3
Common Wall Soundproofing
A layering system is available that can be applied to most any common wall noise issue. Adding both "density" and "disconnection" to your surface can help force the collapse of the transmitting sound wave, and reduce up to 90% of the noise from passing through the wall. Results will vary depending on leakage, ventilation, plumbing, electrical, floors, ceiling, etc.
NetWell is offline   Reply With Quote
Old 09-12-2012, 04:16 PM   #4
Soundproofing Guy
Rewards Points: 158
MLV? Not so easy to work with, and is about the most expensive source of mass available.
Also to the OP, is this pipe noise (you can hear the rushing of water through the waste pipe) or is this an airborne sound issue (people singing in shower, let's just say)? Also, does this wall have a door? If so, that's where you would initially focus your efforts.
Old 09-12-2012, 04:28 PM   #5
MLV is very easy to work with, and not expensive for a bathroom wall. There's hybrid products that are also made with MLV, including pipe and duct wrap lagging material that can help mitigate drain pipe or hvac noise if you have access to them. Bathrooms are tight treatments with many holes cut into perimeter walls, controlling leakage is key regardless of the treatment option. Also, vibration reduction, working to disassemble as best you can the common contact points in your wall, ceiling and floor assembly systems.
Old 09-12-2012, 04:37 PM   #6
Soundproofing Guy
Rewards Points: 158
Soundproofing solutions are largely a mass-based proposition. You'd like to decouple the mass, damp the mass, have some absorption between the mass, but at the end of the day it's all about the mass itself. Specifically, how much of it do we have available? The more the better. We are generally not concerned with the source of the mass, just how much of it there is.
Drywall is 2X the mass and 1/5 the cost of MLV. Instant non-starter.
Old 09-12-2012, 04:59 PM   #7
The instant non starter is forcing a client to double drywall around a bathroom when there's no space to do it. Most of our clients seek to minimize the depth they are adding to a wall assembly, which plays to the advantage of dB-Bloc. MLV measures just .125" thick and requires a single layer of drywall. If there's ever a time to opt out of a double drywall layering system, which most constrained layer damping compounds require, in favor of MLV, it is a bathroom treatment. And no, if you took .125" of drywall and compared to .125" of MLV, MLV carries more density and wins every time. More density, less depth conceded, better collapse in sound bleed, more protection.
Old 09-12-2012, 05:12 PM   #8
Soundproofing Guy
Rewards Points: 158
hmmm. Not seeing any forcing. I think it's either pipes or door.
Even if it were the wall, no way to justify the high cost and relatively low mass of MLV. Wrapping ducts and pipes? Great product because it's flexible. Walls? Waste of funds.
If the OP has a question, I'll reply further
Old 09-12-2012, 06:49 PM   #9
Insatiable Learner
Rewards Points: 166
Smile
Originally Posted by NetWell View Post
Apply to existing finished wall, or exposed frame, and follow the install techniques listed with material.
Been using MLV for a long time and you are right, it is better than drywall, but you're not suggesting they put this on the outside of the wall like wallpaper are you? There are less intrusive ways to cut down the noise from a wall. Also, the OP was not specific enough to say what kind of "noise" they want to get rid of. Using the term "soundproofing" is a bit unrealistic. Dampen would be more acurate.
AngelArs is offline   Reply With Quote
Old 09-12-2012, 07:01 PM   #10
Soundproofing Guy
Rewards Points: 158
AngelArs, may I ask in what way you feel MLV is better than heavier drywall?
Old 09-12-2012, 07:59 PM   #11
Insatiable Learner
Rewards Points: 166
Smile
Hi Ted. Well for one it's lighter so you don't break your back All kidding aside it's not a black or white question. First, MLV is not designed to be exposed to the room, so to use it as the manufacture intended the wall would need to be opened. Most people aren't going to do this. Regarding drywall; It would be a pain to add drywall to an existing wall, especially if that wall contained windows and/or a door. Then you've got to worry about the sound bleeding through the window and/or door. There is a new kind of drywall that came out that is lighter and yet stronger and more dense than standard drywall. It's only 1/2 inch thick and works really well but again, any drywall would be a pain to add to an existing wall.
I have found that most people who aren't in the trade tend to misuse the terms 'soundproof' and 'sound'. Until the OP decodes what they meant, everyone else is just spinning their wheels by suggesting this or that. Something as simple as closed cell expanding insulation will cut down some noise, and it's much easier to install, but who knows if it's good for the type of noise that the OP wants to dampen. All things being equal, if a house was already built I wouldn't use MLV or drywall unless the customer had deep pockets. If the bathroom in question just has noisy plumbing, then just fix the noisy plumbing, after all, it's the source of the noise that they want to remove. If on the other hand they want to dampen the sound of someone singing in the shower, then they need to take other dampening measures. The point is that everyone needs more specific information from the OP before we know how to treat the problem. Bottom line, it's not that MLV is better or drywall is better, because each has their applications. In order to help the OP, they first need to tell everyone what their definition of "sound" is.
Old 09-13-2012, 06:49 AM   #12
dB-BLoc, or MLV, can be applied to an exposed frame or an existing finished surface and yes it is more dense than a .125" thick layer of drywall would be. True, if you double drywall, you trigger density, but the same could be held true if you built an 8' thick wall made out of chicken feathers. The key is to save space and go thin, which is exactly what dB-Bloc does. Layering it to an existing wall is easy, takes less depth, and triggers great STC values when properly installed. AngelArs is correct, each treatment is unique based on the starting point, so some fine tuning would be required to get the treatment right, but the treatment will perform. MLV is a component of an overall assembly system...layered beneath drywall. If the starting point is a finished surface, add the MLV and a firring strip system, then a new drywall layer. It is an easy, inexpensive procedure that works.
Old 09-13-2012, 07:15 AM   #13
Soundproofing Guy
Rewards Points: 158
It's spelled "Furring"
Anyway that creates a triple leaf. Well documented mistake. Don't introduce a second air cavity.
Drywall is 1/5 the cost, and 2x the mass. Keep it simple. If it's the wall, just install a second sheet of drywall from Lowes and call it a day.
Old 09-13-2012, 11:06 AM   #14
Insatiable Learner
Rewards Points: 166
Smile
I suppose any uninformed DIYer could install MLV any way they wanted to, BUT it would NOT be installed correctly. The correct way to install MLV is shown below. Even installed correctly there are better options available.
Between standard 1/2 drywall and MLV, MLV will work better. HOWEVER, between something like Quietrock 510 drywall and MLV, Quietrock 510 drywall will easily outperform MLV every time, and be much easier to install. If they also add some Quietzone insulation, then there is no contest and MLV could not even compete. If you are in the ’soundproofing’ industry and you are using blanket statements and telling your customers that "MLV is better than drywall" and you’re not being specific about what kind of drywall, then you are being dishonest to them and doing a major disservice to your customers.
There are better ways to "go thin" such as using a spray on form of MLV inside the wall. Much easier and quicker to use yoo. The only downside of using it is the smell for the next 3 weeks while it cures
Quietrock 510 has much better STC values than dB-Bloc (MLV).
Correct.
Not to nitpick but it seems you're talking out of both sides of your mouth One minute you're preaching about being thin, and now you're talking about adding furring strips and drywal, Etc.l. Seriously, adding something like one sheet of Quietrock 510 will be much easier, quicker and more direct for the common DIYer, not to mention how much better it will perform.
Old 09-13-2012, 01:05 PM   #15
Soundproofing Guy
Rewards Points: 158
Angel, please don’t take this the wrong way, as I assume you’d rather know truth from fiction. Someone has sold you a bill of goods here.
Once again, mass is mass. Could be Cheerios, Styrofoam, drywall, MLV, etc. Doesn’t matter where the mass comes from as long as there’s a lot of it. MLV does not work any better than other material of comparable mass. Since ½” drywall weighs 60% more than 1/8” MLV, drywall will yield better results, especially on a decoupled assembly. Such is Mass Law. MLV, being a heavy rubber, seems intuitively good for soundproofing, however lab data clearly shows that it’s simply another expensive source of mass. Nothing more.
The specialty drywall referenced is similar to the specialty factory-damped drywall from 4 other manufacturers as well. I have consulted with 3 out of the 5 manufacturers prior to their launching their particular drywall. I’m very familiar with it all and have formally tested various panels in independent labs since 2004. These panels are characterized as being very expensive per square foot (starting at $1.75 a square foot factoring in 11% waste). Second, they don’t weigh much relative to the cost. Given that soundproofing is a mass-driven thing, we want more inexpensive mass, not less mass for much more $$. This is why standard drywall is excellent.
Spray foam is lab tested to be the WORST type of insulation you could consider installing for acoustics. Best for thermal, worst for acoustic. The greater density of the foam does not provide the absorption we need, and foam only serves to reduce our effective cavity depth, thereby further reducing sound isolation. Again, we go to Lowes or Home Depot, and while we’re buying their cheap and massive drywall, we’re also buying their cheap fiberglass insulation.
Lastly, while that drawing is nice, virtually every detail of it is incorrect. There are either completely useless aspects (foam on channel, rubber vibraton pads) or expensive materials that have no business being there (closed cell foam, soundboard, metal tape). The RC-1 Resilient Channel is the one soundproofing product involved in the most lawsuits in the USA. Many acoustical consultants list “expert testimony in Resilient Channel litigation” among their services, that’s how commonly this product fails. I realize that a nice drawing implies truth, but not at all in this case.
Foam and Elastomeric coats over existing BUR ???? sunguy65 Roofing/Siding 2 02-25-2011 12:48 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
How to tap into an existing outlet to add a new one? jimhokie Electrical 10 01-17-2011 01:04 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
