Soundproofing Basement Ceiling With Roxul - Insulation - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 02:38 PM   #1
Rewards Points: 242
Soundproofing basement ceiling with Roxul
I'm currently renovating my basement and am in the process of soundproofing the basement ceiling. My joists are 24'' on center and I just picked up some Roxul Safe n Sound which is made for 24'' centers. The batts are about 3 inches thick, and the problem I'm having is that when I put them up they are sagging in the middle. I'm not sure if this is normal or not
Assuming this shouldn't be happening, I thought about adding some strapping to ensure they don't ever call out completely, especially since I'll only be installing a drop ceiling. Other than that the other option I thought of was to use the Roxul insulation batts that are 24'' on center as I'm thinking these won't sag as much since they're thicker.
Any suggestions?
Lemkie is offline   Reply With Quote
Old 01-18-2013, 02:55 PM   #2
Rewards Points: 578
ive been told that with Roxul you are supposed to use a batt that is slightly wider than the opening, and slightly press in the edges to install it, because that makes it hold itself up. im no pro, but it makes sense in my head.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 01-18-2013, 03:11 PM   #3
Rewards Points: 242
Yes that's what I have here. The batt is slightly wider, however because the batts are 24 inches wide they're sagging
Old 01-19-2013, 10:20 AM   #4
Rewards Points: 216
24" oc, what size are the joists ? what is the room above ?
anyway. don't expect much soundproofing whit that 3".
Fix'n it is offline   Reply With Quote
Old 01-19-2013, 03:18 PM   #5
Rewards Points: 242
The room above is a living room upstairs. I'll have to measure a joist. You say that 3'' won't offer much soundproofing, what would be better?
Old 01-19-2013, 04:30 PM   #6
Rewards Points: 13,256
No insulation hangers?
Old 01-19-2013, 06:28 PM   #7
Rewards Points: 242
I ended up putting it in today with strapping. I had a ton of 3 inch wide pine that I took down during the demo that I saved for this. It worked pretty well. Overall I'm happy I soundproofed. Even at 3 inches it made a noticeable difference.
Thanks!
Old 01-19-2013, 11:53 PM   #8
Registered User
Rewards Points: 5,204
3" is fine; figs. 12, 13; http://www.certainteed.com/resources...%20Control.pdf
Roxul is even better, twice as dense as most f.g.; http://www.roxul.com/files/RX-NA-EN/pdf/SafenSound.pdf
Did you use the Safe-n-sound, or comfort-batt; http://www.roxul.com/residential/res...technical+data
Quieter and greener; http://www.buildinggreen.com/auth/ar...&printable=yes
Gary
Old 01-20-2013, 11:04 AM   #9
Rewards Points: 216
sure, 3" will help. but it will not eliminate all sound transfer. if it were me, i would at least fill the cavity. so if you had a 8" joist, put in 8" of roxul.
i used to live in a modern condo. it had flexicore ceilings http://www.undergroundhomes.com/flexicore.htm
with a layer on concrete on top. i could still hear some things coming from above.
Old 01-20-2013, 12:39 PM   #10
Rewards Points: 242
Gary
I used the Roxul Safe-n-sound. I thought about doubling it up but the research I did suggested it wasn't worth the extra money.
Old 01-20-2013, 05:09 PM   #11
Registered User
Good you did not double it up; "A significant advantage is made by adding higher density insulation in addition to the improvements that can be achieved with other
sound improving methods such as resilient channels, air space depth, or additional layers of wall board.Graph 1, #7: https://docs.google.com/viewer?a=v&q...sMKTgMsl7TruSQ
Roxul recommends the one you used (2.5# density) over the Comfort batt (>2# density) also. The only thing to do better would be the resilient channels rather than wood strapping...
Gary
Old 01-23-2013, 10:45 AM   #12
Rewards Points: 242
Gary
I'm actually going with a drop ceiling in the space. I ordered the Armstrong 5/8 tiles that say they absorb 60% of noise. Seems a little high for a drop ceiling tile but we'll see. Between those and the Safe-n-sound the sound should be half decently stopped I'm hopping.
The Following User Says Thank You to Lemkie For This Useful Post:
Gary in WA (01-24-2013)
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 03:20 PM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
