Soundproofing Basement Ceiling Above Music Room - Insulation - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 01:40 PM   #1
Rewards Points: 298
soundproofing basement ceiling above music room
Hey all - I've got a band practice room in my basement. It's all digital stuff, run through a PA so we don't have booming bass or acoutstic drums. Effectively, it's exactly like just playing a CD through a very loud PA.
The basement is finished with a drywall ceiling.
The first floor right above it is carpeted. You can definitely hear the sound up there - but it's actually not too bad.
Go up to the second floor where all our bedrooms are - and the sound becomes more faint. You can't sing along with the song - and really can only hear some occasional lows/thumps and the beat. It's definitely not enough to wake somebody up - but is just barely enough to make it annoying.
The ceiling above the band space is not insulated since it's interior. So I'm wondering if I could cut some holes in the ceiling drywall and have insulation blasted in. It's also a tray ceiling with soffets for the HVAC. Somehow it would seem to make sense to blast that full as well.
However - I know there is a void there. And I thought voids did a good job deadening sound as well. Maybe insulation really wouldn't make a difference.
I want to avoid using the foam acoustic tiles on the outside for asthetic reasons.
denemante is offline   Reply With Quote
Old 02-19-2013, 07:27 PM   #2
747
registered
747's Avatar
Rewards Points: 534
You can try roxul insulation.
747 is offline   Reply With Quote
Old 02-20-2013, 07:16 PM   #3
If it is lows (bass) you will never eliminate those frequents without a complete gut and sound isolation room. If it was me I would just buy green glue and add a 2nd layer of drywall, or if you have money to burn Green glue then a layer of quiet rock
rebelranger is offline   Reply With Quote
Soundproofing a basement room MrAngles Insulation 5 06-06-2012 10:01 PM
Unfinished/Unheated Basement Ceiling Insulation mcusumano Insulation 4 08-31-2011 06:17 PM
Cold air return for basement room mr.Z HVAC 6 09-08-2010 05:17 PM
new basement room circuit BlueBSH Electrical 9 09-03-2010 09:44 AM
