-   Insulation (http://www.diychatroom.com/f103/)
-   -   soundproofing basement ceiling above music room (http://www.diychatroom.com/f103/soundproofing-basement-ceiling-above-music-room-172384/)
denemante 02-19-2013 01:40 PM
Hey all - I've got a band practice room in my basement. It's all digital stuff, run through a PA so we don't have booming bass or acoutstic drums. Effectively, it's exactly like just playing a CD through a very loud PA.
The basement is finished with a drywall ceiling.
The first floor right above it is carpeted. You can definitely hear the sound up there - but it's actually not too bad.
Go up to the second floor where all our bedrooms are - and the sound becomes more faint. You can't sing along with the song - and really can only hear some occasional lows/thumps and the beat. It's definitely not enough to wake somebody up - but is just barely enough to make it annoying.
The ceiling above the band space is not insulated since it's interior. So I'm wondering if I could cut some holes in the ceiling drywall and have insulation blasted in. It's also a tray ceiling with soffets for the HVAC. Somehow it would seem to make sense to blast that full as well.
However - I know there is a void there. And I thought voids did a good job deadening sound as well. Maybe insulation really wouldn't make a difference.
I want to avoid using the foam acoustic tiles on the outside for asthetic reasons.
747 02-19-2013 07:27 PM
You can try roxul insulation.
rebelranger 02-20-2013 07:16 PM
If it is lows (bass) you will never eliminate those frequents without a complete gut and sound isolation room. If it was me I would just buy green glue and add a 2nd layer of drywall, or if you have money to burn Green glue then a layer of quiet rock
