Soundproofing Apartment - Insulation - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 09:55 PM   #1
analogmusicman's Avatar
Rewards Points: 560
soundproofing apartment
I have an apartment in my home. unfortunately, the main space of that apartment is directly below my bedroom and "soundproofing" is definitely called for.( <- me,when the tenant turns on his tv)
since I'll be replacing the carpet in my bedroom eventually,I thought THAT would be the time to put down some sound barrier. (I've seen some that appear to take the place of the carpet pad) But,now I'm thinking I may go berserk if I wait that long. any ideas about soundproofing with existing carpet already installed? (I've read where "cellulose insulation" works good between floor joists but how do you get it in there? any help?
tnx,
analogmusicman is offline   Reply With Quote
Old 11-07-2011, 12:50 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,790
Any insulation will work in this case.
Most folks go with a Mineral wool but that will require pulling up the plywood flooring whereas you could more easily cut some access holes to pack with cellulose as long as there are no insulation contact issues.
Old 11-13-2011, 12:02 PM   #3
Lowes Carries a drywall product called "quiet board" it is supposed to reduce about 20db. If layed on top of existing plywood/drywall it would be even more
Rono8582 is offline   Reply With Quote
Old 11-13-2011, 02:39 PM   #4
Rewards Points: 560
I've looked at some stuff on the web, sold in 4x8 sheets,looks like it replaces the pad under the carpet. so when I redo the carpet in the bedroom (the existing carpet is 30 years old) I'll probably put that down.
tnx,
Old 11-13-2011, 02:52 PM   #5
Too Short? Cut it Again!
You can rent a machine and blow insulation in.
You do not want to get rid of carpet padding or your new carpet will wear very quickly. This is not to say putting the sound insulation board down not a good idea too. Cork is also a good sound insulator.
They make some recording style sound baffle panels that actually look rather cool on ceilings. Tad expensive though.
Advice on Acrylic smell/fume in my apartment bolland General DIY Discussions 1 10-12-2010 11:08 AM
Different options for soundproofing a finished basement apartment mz04zf Building & Construction 2 09-09-2010 10:18 AM
HELP old apartment .. Return Duct / Heat pump thethrowdown HVAC 1 01-29-2010 03:36 PM
soundproofing question - apartment challenge josefismael Remodeling 3 07-25-2009 06:59 PM
soundproofing a basement apartment amakarevic Building & Construction 3 01-17-2008 05:51 PM
