-   Insulation (http://www.diychatroom.com/f103/)
-   -   soundproofing apartment (http://www.diychatroom.com/f103/soundproofing-apartment-122609/)
analogmusicman 11-06-2011 09:55 PM
I have an apartment in my home. unfortunately, the main space of that apartment is directly below my bedroom and "soundproofing" is definitely called for.:eek:( <- me,when the tenant turns on his tv)
since I'll be replacing the carpet in my bedroom eventually,I thought THAT would be the time to put down some sound barrier. (I've seen some that appear to take the place of the carpet pad) But,now I'm thinking I may go berserk :) if I wait that long. any ideas about soundproofing with existing carpet already installed? (I've read where "cellulose insulation" works good between floor joists but how do you get it in there? any help?
tnx,
Windows on Wash 11-07-2011 12:50 AM
Any insulation will work in this case.
Most folks go with a Mineral wool but that will require pulling up the plywood flooring whereas you could more easily cut some access holes to pack with cellulose as long as there are no insulation contact issues.
Rono8582 11-13-2011 12:02 PM
Lowes Carries a drywall product called "quiet board" it is supposed to reduce about 20db. If layed on top of existing plywood/drywall it would be even more
analogmusicman 11-13-2011 02:39 PM
I've looked at some stuff on the web, sold in 4x8 sheets,looks like it replaces the pad under the carpet. so when I redo the carpet in the bedroom (the existing carpet is 30 years old) I'll probably put that down.
tnx,
user1007 11-13-2011 02:52 PM
You can rent a machine and blow insulation in.
You do not want to get rid of carpet padding or your new carpet will wear very quickly. This is not to say putting the sound insulation board down not a good idea too. Cork is also a good sound insulator.
They make some recording style sound baffle panels that actually look rather cool on ceilings. Tad expensive though.
