Sound Reduction With Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 05:51 PM   #1
Sound reduction with insulation
We have main level room that sits above the basement utility room which houses the furnaces, water heater, and lift pump. The ceilings in the utility room are exposed. Several pipes/duct work run through the expose floor joists as well. We are trying to prevent sount from this room being heard in the main level bedroom above it.
Would insulation in the utility room ceiling help this?
atDev is offline   Reply With Quote
Old 08-08-2012, 08:32 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Insulation inside the floor joist cavities will help a bit, but to work very well you need to uncouple the floor joists and drywall.
Old 08-09-2012, 02:46 AM   #3
Rewards Points: 1,092
any way to get heavy pads on the floor above, like dense pads under the carpet (if you have carpet)? sound deadening sheet rock on the ceiling should help, too.
Old 08-09-2012, 10:08 PM   #4
Rewards Points: 166
if you can, build a separate ceiling below the joists. fill the voids with mineral wool, then drywall.
Fix'n it is offline   Reply With Quote
sound reduction in bathrooms daudlm Building & Construction 3 04-23-2011 07:45 PM
Ceiling Insulation/ Sound Proofing - Waste of time? DTproject Insulation 4 04-07-2011 11:08 AM
Sound Insulation papageek Insulation 1 03-10-2011 04:56 PM
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 04:44 PM
sound insulation between 1st & second floor gretchenmay1 General DIY Discussions 1 02-15-2010 05:42 PM
