Sound Proofing Walls - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 09:46 AM   #31
Rewards Points: 346
Hi Ted - thanks for the valuable info. Any thoughts on the type of caulk with drywall to further enhance soundproofing? I know some companies offer fancy caulk for soundproofing but wasn't sure if I can use standard caulk?
sbkim is offline   Reply With Quote
Old 05-27-2012, 10:46 PM   #32
Registered User
Rewards Points: 526
While you are waiting for Ted's reply, sit back and enjoy some soothing music:
Gary
P.S. Keep the volume low....
Old 05-29-2012, 06:15 PM   #33
Soundproofing Guy
Rewards Points: 158
Wow. That was soothing... Not a good comparison, just FYI. Walls and floors are bounded by mass layers. In a wall you'd want cheap fiberglass.
You can use standard caulk, but you may find a quality acoustical sealant for the same price per fluid oz. as a quality 50 year latex painters caulk.
Ted White is offline   Reply With Quote
Old 05-29-2012, 06:44 PM   #34
Rewards Points: 346
Thanks Ted. That's exactly what John H told me today any suggestions on which areas require caulking other than the obviously seams at the top and bottom of drywall? Thanks
Old 05-29-2012, 07:10 PM   #35
Soundproofing Guy
Rewards Points: 158
That's funny. Aside from the perimeter when both layers are done, you will seal outlets and other penetratons. Also, as you're drywalling, if there are gaps 1/4" or larger, put a bit of sealant in there as well.
Old 05-30-2012, 08:50 AM   #36
Rewards Points: 346
Ted - one more question if you don't mind. I presume many acoustical caulks (such as USG and OSI) are not water based so more difficult to work with vs. 50 yr latex caulk? I just want to provide fool proof items for my builder to avoid any hassles and errors.
Old 05-30-2012, 08:53 AM   #37
Soundproofing Guy
Rewards Points: 158
I would recommend using the product designed for a specific application. I would not use bath caulk on windows, and would recommend acoustical sealant for this application.
Most acoustical sealants are water based.
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
Sound proofing ceiling West4141 Building & Construction 4 02-28-2009 01:26 PM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
Sound proof walls!!! Fux39 Building & Construction 3 11-29-2006 08:28 PM
