Sound Proofing Room - Insulation - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 01:25 PM   #1
Rewards Points: 31
Sound proofing room
I am building new construction and want to build a home music studio in the basement of my house. is there a recommended material better than foam board for this. Iplan to wrap the walls and ceiling to make it sound proof
jbillups is offline   Reply With Quote
Old 03-05-2013, 07:17 PM   #2
Registered User
Rewards Points: 5,516
Ted White is the guy for that, I'll send him a PM. While waiting, for your reading enjoyment; http://www.diychatroom.com/search.php?searchid=3879478
http://www.gp.com/BUILD/product.aspx?pid=1071
http://www.certainteed.com/resources...%20Control.pdf
http://www.roxul.com/residential/pro...sound%E2%84%A2
Tips; http://www.cmhc-schl.gc.ca/publicati...h/2000-109.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Ted White (03-05-2013)
Old 03-05-2013, 07:34 PM   #3
Soundproofing Guy
Rewards Points: 158
You'll want to isolate the room, but with the specific goal of isolating the bass. The bass is the challenge.
At the heart of this is mass. We want as much as possible, and this often means two sheets of 5/8" drywall. Great mass at a great price.
Next decouple the mass from the "original" house structure by deploying framing techniques like staggered stud or double stud walls, clips & channel, etc.
Then damp the double drywall panels with a quality damping compound. It goes between the drywall layers.
Use standard fiberglass insulation in the wall and ceiling cavities.
That will get you your bunker, and a wonderful thing it will be. But now you have to cut a bunch of holes in it. You'll need a door, maybe some recessed lights, ventilation, etc. All of these can compromise the job you did on the ol' bunker. So plan carefully and you will be shocked at the level of sound isolation you can achieve.
Ted White is offline   Reply With Quote
Old 03-09-2013, 05:39 PM   #4
JPL
This is pretty vague.... Yes you need to isolate all structure. You also need to build the ceiling so it doesn't resonate. In either direction. Stuff the framing with rock wool, sheetrock with 5/8 and tape. Install RISC-1 clips and hat channel. Then hang two more layers of 5/8" rock on that. Keep it away from the walls and use acoustic caulking around the perimeter.
Noise control is tough. Think vibration and airflow. You need to stop, or at least minimize both.
JPL is offline   Reply With Quote
Old 03-09-2013, 05:45 PM   #5
Soundproofing Guy
Rewards Points: 158
That would create a triple leaf. Lab proven to perform poorly. Simply eliminate that first layer of drywall and just install the clip directly to the joist.
Old 03-09-2013, 06:33 PM   #6
JPL
You can quote lab results all day. Dean Gainer spec's this, and I tested the results in field. You couldn't hear jumping on the floor above, no voices, no bells, no loud music- just quiet. Residential noise control is way different than commercial. I've seen what worked- and what didn't.
The best way to do it is a structure within a structure. Ala Skywalker studios. That even has RF shielding and an isolated floor.
Old 03-09-2013, 07:24 PM   #7
Soundproofing Guy
Rewards Points: 158
Data is data, but choice is always yours.
Old 03-12-2013, 09:43 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
Sound proofing nerd fight...
Just kidding of course guys.
Good information Ted. Soundproofing was always a bit hazy to me to start with but I have read your posts and you are the man.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Ted White (03-12-2013)
Old 03-12-2013, 10:10 AM   #9
Soundproofing Guy
Rewards Points: 158
LOL!!
Stepping Down Into Room. Code question bduncan118 Building & Construction 13 02-03-2013 09:29 PM
Return-air Sound Proofing jacquesstrap HVAC 4 02-08-2012 03:59 PM
Sound proofing god General DIY Discussions 20 01-05-2011 02:09 PM
sound proofing ceiling gonefishin1 Flooring 2 12-09-2009 12:15 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
