Sound Problem - Insulation - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 11:01 AM   #1
Sound problem
Have a customer that lives in a condo with a shared wall. She complains that she can hear every little thing on the other side. I checked the walls, and they're 5/8 rock with what looks like mineral wool insulation.
Any ideas on sound proofing? How much do you think a Sheetrock overlay would help?
Stanchek is offline   Reply With Quote
Old 01-19-2012, 11:04 AM   #2
What about foam injection on top of the insulation?
Old 01-19-2012, 11:07 AM   #3
Rewards Points: 14,300
Must be an older unit. Any new constrution would have called for party walls.
One wall is build and sheetrocked than another wall is built making sure the studs do not line up with the wall behind it, insulate with fiberglass batts and then sheetrocked.
Adding another lay will do very little. Air space would be needed between the layers.
Just do a Key Word search on the net on sound proofing.
Old 01-19-2012, 11:54 AM   #4
AGWhitehouse's Avatar
Sheetrock overlay on each side using this: http://www.soundproofingcompany.com/...t-sound-clips/
will certainly help...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Windows on Wash (01-20-2012)
Sound under house about every 15 mins Denise5667 Plumbing 3 11-20-2011 06:36 AM
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 12:35 AM
constant running sound in house, can't locate, please help! yangyan616 Plumbing 2 09-18-2011 02:07 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
