Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 05-11-2011, 01:34 AM   #1
sound + insulation
i;m putting a bedroom in my basement, what is the best way to soundproof the ceiling?
baflash is offline   Reply With Quote
Old 05-12-2011, 05:17 AM   #2
sdsester's Avatar
sound + insulation
Probably will not be able to "sound proof" it but look for recording studio sound baffle materials if you can afford them. Just insulating the ceiling and drywalling it will help quite a bit.
sdsester is offline   Reply With Quote
Old 05-12-2011, 10:04 AM   #3
Soundproofing Guy
sound + insulation
http://www.soundproofingcompany.com/...fing_ceilings/
An array of various ceiling isolation options and their relative performance.
If you want a lot of isolation, the #1 thing to do is decouple the ceiling drywall from the joists. That alone will put you in a higher isolation category.
Don't spend a lot of time and money looking at insulation. Simple R19 fiberglass is excellent. Cheap and about as good as it gets
Stick to massive standard 5/8" drywall at $8 a sheet. Excellent source of mass
Ted White is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 04:44 PM
sound insulation between 1st & second floor gretchenmay1 General Discussion 1 02-15-2010 05:42 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
