So I Need A Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 08:53 AM   #1
Rewards Points: 41
My house is like this - Vinyl siding to 1/2 inch fan fold foam board to house wrap to wall boards to 2x4 studs I will be extending the studs to 2x6 and fitting in Roxul R23 comfort batt. Once I put the Roxul in the the studs do I need to put on a 6mil plastic wrap for vapor barrier or do the other items i mention act as a vapor barrier? Central Maine is my loaction.
biddlecom is offline   Reply With Quote
Old 09-20-2013, 09:11 AM   #2
Rewards Points: 12,802
I would not do it, I believe that would form a double vapor barrier.
Old 09-20-2013, 01:23 PM   #3
ccarlisle's Avatar
No. You already have an R1.5 3/8" thick vapour retarder on the outside and whatever you put up on top of the Roxul would be another vapour retarder. So the ability of vapour to travel inside to outside and/or outside to inside is reduced sufficiently to avoid condensation.
However, I'd put up gyproc walls and paint them - properly - with latex paint to have a good vapour retarder on the inside. Caulk the gyproc panels to the studs using sealant to reduce air movement - which is what does the carrying of the vapour.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 09-20-2013, 07:19 PM   #4
Registered User
Rewards Points: 4,902
The fan-fold (1/2") may have a perm rating of 1.1 Perms; http://www.google.com/url?sa=t&rct=j...52434380,d.cGE
For your location, Zone 6; http://energycode.pnl.gov/EnergyCode...sp?state=Maine
With over 1 perm at sheathing, you are vapor semi-permeable and require asphalt faced paper, SVR, or v.b. paint next to the drywall, Fig.4a: http://www.buildingscience.com/docum...nd-wall-design
SVR; http://www.bestofbuildingscience.com...3-4_p37-40.pdf
Gary
