Small Insulation Paper Backing Rips - Insulation - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 10:06 PM   #1
Removed some wall speakers and some of the insulation backing behind the speakers was ripped. Should I use tyvek tape on the paper backing, another type of tape or let it be? Total insulation paper riipping is less than 2' in two areas.
ken57 is offline   Reply With Quote
Old 01-29-2012, 10:14 PM   #2
Rewards Points: 12,818
Not a big deal, if it makes you feel better put some tape on it.
? How did the speakers get in contact with the insulation in the first place.
There is drywall over the insulation, right?
Big fire hazard to leave it uncovered.
Old 01-30-2012, 12:32 AM   #3
Thanks. The speakers were surface mounted directly in the wall
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Cantilevered floor insulation rickswa Building & Construction 5 01-02-2008 01:08 AM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-17-2006 12:00 AM
