Small Gap Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 01:25 AM   #1
Small gap insulation
Is there anything I can or should put between these studs? The facing side in the inside of the bathroom. What you see between the studs is just a layer of fake wood paneling. On the other side is the pathway to the basement. I'm thinking of some of that foam sheeting. If for no other reason than to give the wall some volume. Is this a good idea or do you suggest something else?
enigmaingr is offline   Reply With Quote
Old 09-08-2011, 11:06 PM   #2
Are worried about sound or insulating temp from the basement?
Kriddels is offline   Reply With Quote
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Floor insulation for small room over inaccessable crawl space. EdT Insulation 0 05-13-2011 11:25 AM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
