Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-09-2012, 10:38 AM   #1
Skylight shaft insulation
Our master bath has skylight and five recess lights....its kind of
cold!. I am thinking to install tenmat covers over recess lights. What would be the proper way to insulate shaft from the attic? Any other ideas for recess lights, except tenmat cover?
Thanks!
Click image for larger version
Name:	2012-10-08 19.40.17.jpg
Mikhail is offline   Reply With Quote
Old 10-09-2012, 10:44 AM   #2
Those cans needed to be I/C air tite cans. If not your going to need to come out with a box around them to seal them and keep them away from the insulation.
I would air seal around them with foam, seal any holes where the wires where run, and use blown in type insulation, not batts. No need to have a blower, just pore it around the area.
Mikhail (10-09-2012)
Old 10-09-2012, 11:09 AM   #3
Thanks for info!
What would you reccomend to use on actual skylight shaft? Picture above is shown skylight shaft with recess light in it.
Old 10-09-2012, 12:05 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rigid board installation with fiberglass or other fibrous insulation around the outside of the skylight shaft will work well.
Box in the can lights with fire rated drywall caulking and foam then insulate overtop with loose fill insulation as Joe indicated
Old 10-14-2012, 10:19 PM   #5
It looks like framing around the skylight is build from 2x4, so in order to fit batt insulation and then rigid board on top of it, I have to build additional frame at least around two of the sides. Otherwise, I won't have space for batt insulation. Is it worth to do that? What would be the other options? Maybe bat insulation and then wrap everything in reflective insulation/barrier. Something like that:
http://www.lowes.com/pd_409819-56291...ier&facetInfo=
Old 10-15-2012, 08:05 AM   #6
Radiant barrier provides zero insulation value.
Post up a picture and I will tell you how to do it but there is no reason that with some batting and rigid foam you can't get it done.
You could also just use batting with a air barrier over top (i.e. Tyvek) as well.
Old 10-15-2012, 09:20 PM   #7
Took some pictures tonight.
1st picture is right side of the skylight shaft
2nd picture is front of the shaft with recess light
3rd picture is again right side.
I didnt took picture of left side, because is the same as right side. And back is tight space even for my hand.
My point is that framing is build from 2x4 and its not deep enough for batt insulation plus rigid on top.
Skylight shaft insulation-2012-10-15-19.10.55.jpg   Skylight shaft insulation-2012-10-15-19.11.34.jpg   Skylight shaft insulation-2012-10-15-19.12.16.jpg
Old 10-16-2012, 08:26 AM   #8
Either or then.
You can cover it with batts and staple it to the surface as long as you cover with some sort of air barrier (i.e. tyvek) or just cover it with foam.
Be sure to seal all the seams first in both options.
Insulating your attic Bob Mariani How To Guides 2 03-01-2012 06:56 PM
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 8 02-24-2012 10:09 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
reflective material in skylight shaft? ilyaz Remodeling 1 03-02-2010 05:58 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
