Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-08-2012, 02:09 PM   #1
Simple insulation question
I'm adding insulation to the walls separating the living space from the crawl spaces in my finished attic. Currently nothing there but panelling. Is it ok to use batts? With or without facing?
Should the facing go on the interior or exterior side? The exterior side (inside the crawl space) is the open wall, not the living space side.
Thanks.
jmorc2003 is offline   Reply With Quote
Old 11-08-2012, 09:43 PM   #2
can you get to the backside of this crawlspace ?
do you have any pics ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Old 11-08-2012, 09:47 PM   #3
Exterior Construction
Windows on Wash's Avatar
Vapor retarder recommendations are climate specific.
Where is the home located?
That all being said, the rigid board will outperform the batts.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Gary in WA (11-08-2012)
Old 01-29-2013, 11:45 PM   #4
I have a similar issue in a new thread I started. Would you guys mind taking a look?
Unique attic situation and need assistance
What did you end up doing with this project?
thanks
mystic_cobra is offline   Reply With Quote
Old 01-30-2013, 07:23 AM   #5
Windows & Remodeling
HomeSealed's Avatar
Those are called knee-walls. Around here we typically air seal the penetrations, add or reinstall the batting in the cavities, add another layer of batting horizontally, and then wrap over with tyvek.
the rigid board works as well, but it can get pricey.
HomeSealed is offline   Reply With Quote
Basement Insulation Question gilbo125 Building & Construction 9 02-01-2011 05:13 AM
Insulation question Branden Building & Construction 1 08-03-2010 02:02 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 03:51 PM
Simple question - proper direction of ceiling insulation jizzle Building & Construction 2 01-07-2009 10:08 PM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
