Shower:Redgard, Durock, Roxul, Blackboard - Insulation - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 12:58 PM   #1
Rewards Points: 150
About to install Durock, Stud cavities are sealed, the blackboard seems to have an asphalt coating on it.
I'm not using any kind of VB (other than Red Gard).
It's been suggested that I use a tar paper liner between the Durock and the studs. Any of the experts take exception to this? I believe TP is vapor permeable, so there shouldn't be an issue there.
Thanks!
rightit is offline   Reply With Quote
Old 06-19-2012, 04:03 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,184
Tar paper is not a class I vapor retarder. Ideally, you new wall should be bulk moisture tight and vapor tight to prevent the vapor from entering the wall at all and allowing it to dry to outside if possible.
Where is this can be problematic is if the interior wall is the cold wall (far South and humid).
More details about your location are helpful but if you keep the bulk moisture out (most tile jobs do not) you are ahead of the game.
Old 06-19-2012, 05:30 PM   #3
Rewards Points: 150
Hi WoW. It should dry to the outside OK. BB (with asphalt coating) with a brick cladding. And yes, as you may remember, deep south.
The only vapor retarder will be the Red Gard.
The plan is tile, Red Gard, Durock (on wood studs), Roxul, BB (as above), 1" gap, brick.
All is air sealed. stud cavities are air sealed with silicone, all top plate penetrations are sealed with tumescent fire caulk (pressed in and completely filling hole)
External (shower) walls: 4' wall is east facing, the other external 3 ' wall is south facing.
I've been planning on tile, as it's hard to beat the appearance with marble, etc.
I should have been more clear about the TP. It was suggested just as an additional layer behind the durock that would protect the studs from moisture, but I'm not so sure about using it in this application.
Do you see any issues with this plan (less TP, I guess)?
Is my Roxul sound insulation toxic? Brit Insulation 20 08-12-2012 09:13 PM
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 07:48 PM
Gap between tub and durock (not lip) megablok Flooring 19 04-05-2012 10:15 AM
Liner and Durock placement rightit Kitchen & Bath Remodeling 7 03-13-2012 06:35 AM
Durock Question md2lgyk Concrete, Stone & Masonry 7 02-18-2012 07:25 AM
