Should This Wood Be Insulated? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 08:07 AM   #1
Rewards Points: 150
should this wood be insulated?
After reading articles on building science website (see post on this site- airspace yes or no?) I'm wondering if all this wood should have some type of insulation over it or some type of thermal break. Out side is already sided with just house wrap and 1/2" ship lap pine. I live in north west central New Hampshire.Any thoughts? Thanks
should this wood be insulated?-dsc01412.jpg   should this wood be insulated?-dsc01409.jpg
hpyjack2013 is offline   Reply With Quote
Old 09-19-2013, 08:31 AM   #2
Rewards Points: 13,968
That's a whole lot of lumber to hold up a ridge beam.
When we do one like that we have used 12" wide LVL's as the header, and run them from outside to outside of the doors so there's less support needed in the middle and wires can be run.
Electrical inspector may have something to say about there not being an outlet between those doors.
A layer of 1/2 blue foam insulation and some jamb extensions may be called for.
Old 09-19-2013, 10:56 AM   #3
Rewards Points: 150
Thanks for the reply. There was a redesign after the project go started. It originally did not call for two sliders to be on that wall, and it was quicker to use the 2x6's then have to wait for lam beam. electrical inspector/building inspector gave permission to notch out out "beam". Not going to. going with surface mount wire mold and box. Thanks again.
Old 09-19-2013, 01:26 PM   #4
Rewards Points: 1,668
Looks like there may be a brown bear in your yard and the neighbor's trees are too tall.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
operagost (09-23-2013)
Old 09-19-2013, 04:22 PM   #5
Registered User
Rewards Points: 526
Yes R-7- is lame for that location, soft wood lumber; http://www.coloradoenergy.org/procor...f/r-values.htm
Don't stuff f.g. around units; http://books.google.com/books?id=a29...(1995)&f=false
With your inset stapling above, air block f.g. batt ends against wind-washing leaving room for ventilation. This will also limit infiltration at the insulation/drywall interface resulting in convective loops if low density- what R-value? https://docs.google.com/viewer?a=v&q...M8l_EeA2F-qvvA
Figs.3a&b; https://docs.google.com/viewer?a=v&q..._NGatSVo3wzmAQ
IMO, if affordable- add XPS before drywall on ceiling slope; http://www.buildingscience.com/docum...n-roof-venting
Gary
PS. check the other post as I left another link (you need to air-seal to get benefit of "dead air").Need drywall wall backing above the header tops, even when floating it...
Framing a non-load bearing basment wall (to be insulated) - Wood or steel? kuj0317 Drywall & Plaster 5 11-03-2011 10:37 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
