Should I Seal Up Attic Window? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 12:59 PM   #1
Should I seal up attic window?
House was built in 1951 and has a "typical" window right below the gable vent. The bad thing is that this is the side that gets hammered with sun.
Would it be better to just remove the window, frame out the remaining hole and put in another vent or just leave the window but seal and block the sunlight from entering the attic?
saladdin is offline   Reply With Quote
Old 09-21-2011, 10:04 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
You can just put a foil covering to the inside surface of the window or a light colored fabric. That will negate much of the radiant heat gain.
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
How to properly seal window in tiled shower stall. Proby Kitchen & Bath Remodeling 0 07-21-2010 11:49 AM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 04:27 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
