Should I Insulate This Void? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 04:02 PM   #1
DIY'er
DIYadam's Avatar
Should I insulate this void?
Going to be doing electrical and insulation this evening and I was wondering about this void that is the depth of a 2x4.
Should I fill it with insulation as well or just leave it empty? Something is telling me leaving it empty is not a good idea.
Any ideas? Here's a pic.
DIYadam is offline   Reply With Quote
Old 08-27-2011, 03:35 PM   #2
Registered User
Rewards Points: 5,212
I would use rigid foam board there; http://www.buildingscience.com/docum...gs?full_view=1
Because; http://www.quadlock.com/technical_li...Insulation.pdf
Gary
Old 08-30-2011, 01:23 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,794
Yes.
Rigid board would be great on the walls.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Void under toilet flange that is set on slab Homerepairguy Plumbing 4 12-06-2010 10:59 PM
To insulate or not to insulate? brokenhammer Building & Construction 2 11-24-2010 07:10 AM
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 12:13 PM
Insulating void between headers pshadwick Building & Construction 2 04-06-2010 02:35 AM
