Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-18-2012, 11:34 PM   #1
Green Hat
Should I insulate garage walls?
Hey guys, just noticing as it gets colder that one side of my house is about 5-6 degrees colder than the other. Just so happens that the garage is underneath. Not a big deal to me, but my 7 month old son's room is above it and we have to crank the heat up to make sure he stays warm.
The floor (garage ceiling) has insulation, but the garage walls do not, nor do the garage doors.
Generally, the garage is only about 10-15 degrees warmer than outside.
Could this be the culprit? If so, should I frame the garage, insulate......and sheetrock? Or do I have any other options? I have a ton of tools in the garage, so its not bare by any means.
Mills314 is offline   Reply With Quote
Old 01-18-2012, 11:52 PM   #2
Moderator
Figure #7: http://www.buildingscience.com/docum...n-crawlspaces/
Cover with 5/8" drywall and fire-taped, long screws (section on foamboard): http://gypsum.org/pdf/GA-216-2010.html
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 01-18-2012, 11:53 PM   #3
Rooms over garages almost always end up feeling colder. The builders tend to not put enough insulation in that ceiling.
I see no way insulating the walls will have any effect.
Is there seals around the outside of the garage door?
Have you sealed any holes you can find where wiring was run in the top plates?
What kind of flooring do you have in there?
Should I insulate an attached garage? pbkid Building & Construction 11 07-09-2011 03:31 PM
leaky garage walls zehavit Building & Construction 0 12-31-2010 05:43 PM
garage walls Millsy Building & Construction 6 08-10-2010 09:10 PM
Insulate garage? BlueBSH Building & Construction 5 04-09-2010 10:52 PM
Insulate Side Walls of Row house acerunner Building & Construction 1 03-27-2010 12:11 PM
