Should I Insulate This ? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 09:21 PM   #1
Should I insulate this ?
22'X30' addition- crawl space only. Block foundation walls.
I have installed 4'x8' sheets horizontally, of O Corning 2" foam board along entire inside of block wall foundation.
Do I now need to insulate between the 16"OC I Joists, or is the crawl space now insulated enough ?
stymie222 is offline   Reply With Quote
Old 06-16-2011, 08:11 AM   #2
Rewards Points: 320
Where are you located? At least down south, if you put fiberglass or even open cell spray foam in between the joists they will hold moisture and will not hold up and eventually could cause rotting unless you create an air tight seal around it. If you've completely sealed up the walls with insulation, you'll probably want to put down a moisture barrier along the ground.
autx790 is offline   Reply With Quote
Old 06-16-2011, 08:20 AM   #3
Live in Iowa. Very cold winters.
Would 6" thick batts be adequate for 9 1/2'" I joists, or go for the 9 1/2" batts ?
I don't know if this info is right- The Mid American energy consultant said I didn't need the I joists insulated if I installed the foam board. Kind of shook my head on that one.
I will put down 6mil poly on entire floor.
Thanks for the reply.
Old 06-16-2011, 09:17 AM   #4
Rewards Points: 320
If the space is now sealed up i'm not sure how much gain you receive in insulating between the joists. I just know that if your going to seal up your crawlspace but dont put a membrane down on the ground, you will get moisture coming up from the ground.
You could read the info here on crawl spaces, they have some good info on how best to do all this.
http://www.buildingscience.com/resou...nd-crawlspaces
http://www.buildingscience.com/docum...ance-and-codes
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
To insulate or not to insulate? brokenhammer Building & Construction 2 11-24-2010 07:10 AM
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 12:13 PM
How to Insulate behind Wall Stack Supply Duct whirly HVAC 5 03-08-2010 05:47 PM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 07:07 PM
