Shoud I Reuse And Throw Away ? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 09:44 AM   #1
Rewards Points: 282
Shoud I reuse and throw away ?
One of my room has dropcelings. I plan to put a drywall instead of dropceiling. So I did find insulation on top of the drop ceiling panels.
How do I know the insulation is no longer good ? Can I reuse it when i put my drywall or should I throw it out and use new insulation ?
http://i699.photobucket.com/albums/v...1/P1010030.jpg
http://i699.photobucket.com/albums/v...1/P1010029.jpg
cprao is offline   Reply With Quote
Old 02-22-2012, 09:50 AM   #2
Rewards Points: 12,830
Looks like there may be mold growing on it. Most often caused from lack or venting, dryer or bathroom vent just blowing into the attic instead of being vented outside?
Old 02-22-2012, 10:24 AM   #3
Rewards Points: 282
Thank you !
There is no bathroom in this area but dryer and washer is there but dryer has a vent.
So what should I be doing now ? throw this out and buy new insulation ?
Old 02-22-2012, 11:39 AM   #4
rditz's Avatar
chuck it...
how well is the attic space vented?? are there any black patches on the roofing material?? this would indicate insufficient venting
rditz is offline   Reply With Quote
Old 02-22-2012, 03:07 PM   #5
bikerpowell's Avatar
Yeah, it is no longer good. I see mold
bikerpowell is offline   Reply With Quote
Old 02-22-2012, 10:44 PM   #6
Registered User
Rewards Points: 4,912
Throw it, could be mold with the washing machine and the warm, moist air rising between the grid: http://www.inspectapedia.com/sickhou...rglassMold.htm
I see some air infiltration: http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Gary
Gary in WA is online now   Reply With Quote
Old 02-22-2012, 11:50 PM   #7
Rewards Points: 282
Gary
Ok. Got it. Thank you. I will replace this with new insulation.
Also - I need to see how to ensure enough vent to the attic.
Old 02-24-2012, 01:23 AM   #8
Registered User
look for a plastic vapor barrier under the insulation on the drywall ceiling below. If so, use the 300, if not- the 150: http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Old 02-24-2012, 10:44 PM   #9
Rewards Points: 282
Gary
What is 300 ?
You mean to say - lay down vapor barrier on drywall then install insulation..?
Old 02-25-2012, 09:57 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Originally Posted by cprao View Post
What is 300 ?
300 is the ratio of footprint to ventilation requirements.
Google Attic Ventilation and NFA requirements.
Old 02-25-2012, 11:10 PM   #11
Registered User
My Post #8, just below the chart (in the link):
THE SIMPLE MATHEMATICS OF A BALANCED RIDGE VENTILATION SYSTEM
  • According to most building codes, you need 1 square foot of ventilation for every 150 square feet of attic floor space.
  • For new home construction that includes a vapor retarder, the minimum is 1 square foot of ventilation for every 300 square feet of attic floor space.
Gary
Old 02-26-2012, 02:42 AM   #12
Rewards Points: 282
Gary
Got it about attic floor space.
Regarding vapor retader - is it a paper kind of material ?
Old 02-26-2012, 02:12 PM   #13
Registered User
http://www.energysavers.gov/your_hom.../mytopic=11810
http://www.buildingscience.com/docum...vapor-barriers
Gary
Old 02-26-2012, 09:46 PM   #14
Rewards Points: 282
Thank you. I will go over contents.
Does anybody reuse wire? jobblyman Electrical 12 10-27-2010 09:04 AM
