Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 05-04-2011, 11:39 AM   #1
Sheetrocking the Basement
Hello, I am planning on sheetrocking the basement in my house. I have a walk out basement so one wall is facing the outside. And there are two walls that I will be sheetrocking that are below grade level. I am wondering what types of insulation are best and how to insulate.
When i took down the old paneling there was the fiberglass R something behind it. Is the fiberglass rolls good enough or do I need to put the vapor barrier up too.
Thanks in advance.
jburchill is offline   Reply With Quote
Old 05-04-2011, 08:03 PM   #2
Moderator
Where are you located?
Gary
Clothes taking longer to dry?
Old 05-05-2011, 10:14 AM   #3
in the tundra of North Dakota
Old 05-05-2011, 10:44 PM   #4
Moderator
No v.b. or vapor retarder required, or suggested; http://publicecodes.citation.com/ico...001_par003.htm
http://www.buildingscience.com/docum...ent-insulation
http://www.buildingscience.com/docum...gs?full_view=1
Gary
Old 05-06-2011, 11:01 PM   #5
Ok, just to clarify this. Since I live in North Dakota I don't need a vapor barrier? I can just use the fiberglass rolls of insulation against the concrete basement wall? I'll check what rating I need. But so it'll be concrete foundation wall, then insulation, then sheetrock?
thank you
Old 05-09-2011, 04:34 PM   #6
Moderator
No v.b. on basement concrete walls if under the 2009 IRC, check locally to be sure. I suggest foam board rather than f.g. on concrete; http://www.swinter.com/services/docu...Insulation.pdf
http://www.buildingscience.com/docum...lation-systems
Gary
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 03:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 04:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
