-   Insulation (http://www.diychatroom.com/f103/)
-   -   Sheetrocking the Basement (http://www.diychatroom.com/f103/sheetrocking-basement-103562/)
jburchill 05-04-2011 10:39 AM
11 Attachment(s)
Hello, I am planning on sheetrocking the basement in my house. I have a walk out basement so one wall is facing the outside. And there are two walls that I will be sheetrocking that are below grade level. I am wondering what types of insulation are best and how to insulate.
When i took down the old paneling there was the fiberglass R something behind it. Is the fiberglass rolls good enough or do I need to put the vapor barrier up too.
Thanks in advance.
Gary in WA 05-04-2011 07:03 PM
Where are you located?
Gary
jburchill 05-05-2011 09:14 AM
11 Attachment(s)
in the tundra of North Dakota
Gary in WA 05-05-2011 09:44 PM
No v.b. or vapor retarder required, or suggested; http://publicecodes.citation.com/ico...001_par003.htm
http://www.buildingscience.com/docum...ent-insulation
http://www.buildingscience.com/docum...gs?full_view=1
Gary
jburchill 05-06-2011 10:01 PM
11 Attachment(s)
Ok, just to clarify this. Since I live in North Dakota I don't need a vapor barrier? I can just use the fiberglass rolls of insulation against the concrete basement wall? I'll check what rating I need. But so it'll be concrete foundation wall, then insulation, then sheetrock?
thank you
Gary in WA 05-09-2011 03:34 PM
No v.b. on basement concrete walls if under the 2009 IRC, check locally to be sure. I suggest foam board rather than f.g. on concrete; http://www.swinter.com/services/docu...Insulation.pdf
http://www.buildingscience.com/docum...lation-systems
Gary
