Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-05-2011, 12:06 PM   #1
Sewage leak on insulation
Should all touching rows of insulation be replaced when there was a sewage leak that made one row (between joists) fall. I am concerned about mold and also sanitation because the joist is also wet.. Will the smell draw vectors?
attalla1 is offline   Reply With Quote
Old 08-05-2011, 05:32 PM   #2
Moderator
Welcome to the forum!
We need more information..... Is this a crawl space with under-floor fiberglass batt insulation? What/where was leaking? Once f.g gets wet.....: http://www.totalbasementfinishing.co...shed-basement/
Just when you think you got it all...: http://www.inspectapedia.com/sickhou...rglassMold.htm
Gary
Clothes taking longer to dry?
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
We need more venting and insulation Scott Stevens Roofing 5 10-15-2010 01:55 PM
New Unfaced Insulation Off gassing something common sense Building & Construction 3 10-07-2010 04:46 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
