Sealing Part Of An Existing Ridge Vent - Insulation - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 05:52 PM   #1
Sealing part of an existing ridge vent
I am planning to spray about four inches of closed cell foam insulation to the underside of the roof deck in the kitchen. The kitchen has a vented cathedral ceiling. Additionally, the kitchen and the attached garage share a common roof and one continuous ridge vent. How would I go about sealing the kitchen portion of the ridge vent and not the portion servicing the garage?
ToolMonger is offline   Reply With Quote
Old 07-08-2013, 08:19 PM   #2
Rewards Points: 14,312
If I understand you correctly I'd go up on the roof and remove the vent and add new caps over that area.
Old 07-09-2013, 07:38 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,592
You could just blocker it with rigid from from the interior and put the SPF right over top.
Once the roof is due to be replaced, they can stitch in the new plywood repair if you have the rigid foam there and don't have the SPF right to the deck.
Make sure all the fans and top plates are secure and venting through the roof.
4" of even cc SPF isn't much if you have a cold season and the roof, with enough moisture, will still sweat.
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 03:47 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 07:30 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
