Sealing Crawl Space Rim Joists And Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 10:51 PM   #1
Rewards Points: 152
Sealing crawl space rim joists and walls
Talked to the local building inspector, he noted that our code says to put batt insulation into rim joist, then rigid polystyrene (sealed around perimeter with spray foam or caulk) on next.
Couple things:
1) Don't have a sill plate, the floor joists are resting directly on the concrete foundation wall. Should I put the rigid in flush with the inside of the concrete wall?
2) Foundation wall currently has 2" white foam (EPS?) insulation which I don't think acts as a moisture barrier. Crawl space has plastic on ground, was going to fasten it to the walls at the same time. If the EPS isn't a moisture barrier, should I be bringing the plastic up the walls and fastening to the bottom of the rim joists?
burnt03 is offline   Reply With Quote
Old 11-10-2012, 07:08 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,990
EPS works okay as a bulk moisture barrier. Hopefully they did a good job waterproofing it to outside.
I wouldn't run the plastic all the way up the wall. Its intended purpose is not to trap the bulk moisture in and you would be hiding it where you can't see it.
You will want to know if you have water coming through the wall as compared to trapping it under the vapor barrier.
I would put the rigid tight to the outside wall, seal it up, then cover with a batt for fire protection.
The Following User Says Thank You to Windows on Wash For This Useful Post:
burnt03 (11-10-2012)
Old 11-11-2012, 08:59 AM   #3
Rewards Points: 152
Took a closer look at the insulation, looks like it might be styrofoam?
If so, does it work as a vapor retarder?
Old 11-11-2012, 10:14 AM   #4
Its EPS.
It does work as a vapor retarder but it is more vapor open than XPS depend on skins.
burnt03 (11-11-2012)
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Odor from Crawl Space G Ollis General DIY Discussions 68 11-02-2013 01:31 AM
soft floors, bad joists and shallow crawl space This-or-that Building & Construction 15 02-29-2012 11:39 AM
Crawl Space Advice mjarema414 Building & Construction 0 02-04-2011 08:09 AM
Jacking Up Floor Joists in Tight Crawl Space killerformula Building & Construction 2 06-11-2009 03:23 PM
