Sealing Around Outleys - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 12-31-2016, 08:09 PM   #1
Sealing around outleys
I have cold air coming around outlets. When I pop the cover, I see a gap around the box and feel cold air. Do I need to use 3M Fire-Barrier Caulk or can I use the expanding foam, which is much cheaper.
Shelby2098 is offline   Reply With Quote
Old 12-31-2016, 10:36 PM   #2
Rewards Points: 4,824
Re: Sealing around outleys
Regular foam would work, but messy. Caulking is easier and you can use your fingers. Never touch the foam products before they cure, it doesn't come off.
My trich for air sealing is to use contact paper, the peal and stick variety. Place the switch plate cover on the contact paper and mark out the switch or receptacle whichever. Cut out so paper will fit over the device. You can pre-cut the outside dimension or trim after all is installed. In one case i left the contact paper showing a 3" boarder, helped with the finger prints.
But the paper will give a good air seal right up to the device.
Bud
Bud9051 is offline   Reply With Quote
Old 01-01-2017, 06:46 AM   #3
Rewards Points: 14,312
How old is this house?
Wondering if it's balloon wall construction.
https://www.lowes.com/pd/Frost-King-...f-a1cbdadb78e7
Gymschu likes this.
Old 01-01-2017, 08:21 AM   #4
1978. I actually purchased those and noticed a big difference when installed. There are a couple of outlets that there is a pretty good size gap.
Old 01-02-2017, 08:04 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
I like the foam gaskets, but you have to do them correctly. Do throw out the cut out sections as they are used to seal around the male parts of the plugs and get plugged back in.
Little bit of caulking and some gaskets can tighten them up a good bit. Foam can be a recipe for disaster if you ask me.
Old 01-02-2017, 08:58 AM   #6
Civil Engineer
Rewards Points: 4,954
Do you have insulation in the walls? If so, you need to fill the gap up to the insulation, which may be easiest with expanding foam. Or you can remove some drywall and fill in the insulation with appropriate material, fiberglass, rockwool, cellulose, whatever is in there now. Course then you have to replace the drywall, but its a new year, new project. I recently insulated my garage wall, curiously it was the only wall in the house with no insulation. I took off the drywall, filled the gaps with foam board, and installed new drywall. Much warmer kitchen now (opposite side of garage).
Daniel Holzman is online now   Reply With Quote
Old 02-18-2017, 01:54 AM   #7
Rewards Points: 42
I had the same problem. The builders insulated the laundry room wall, which is actually inside the house, rather than the garage wall. I did the same thing you did, using new 5/8 fire resistant drywall. I sealed all 4 knockout areas on all electrical boxes from the outside when the drywall was down. Then around the boxes once the drywall was up. I used 3M fire caulk. It has a strange mucous-like consistency, unlike normal caulks. It wasn't fun, but it had to be done.
omgdiddy is offline   Reply With Quote
Need advice on brick cleaning / sealing & pavement projects mystiky Concrete, Stone & Masonry 3 08-06-2014 02:30 PM
Electrical outlet sealers versus draft sealing bluefoxicy Insulation 10 01-01-2014 09:55 PM
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
