Running Romex - Insulation - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 04:42 PM   #1
running romex
i installed a tv in my kitchen on the wall and am attempting to run romex for an outlet behind the TV i have cut out my outlet and now am attempting to run romex down to another outlet , but the wall is insulated . How do I get the romex through?
pnut1 is offline   Reply With Quote
Old 03-29-2012, 05:00 PM   #2
Rewards Points: 1,092
Is it legal, and aesthetically acceptable, to run the romex on the inside of the wall, in flex or rigid conduit? Otherwise, tear out as much sheet rock as you need to and drill holes in studs. If the holes are not deep enough (2"?) you'll need metal plates over the holes before you replace the sheet rock. Otherwise, try to go down a flight, if possible, and work through a basement (??????) if you have open floor joists, then pop back up into the wall. That will minimize your destruction. You can drop a weighted string down the wall and catch the wire from below, pulling the wire back up: If you are real lucky.
The Following User Says Thank You to jklingel For This Useful Post:
Windows on Wash (03-29-2012)
Old 03-29-2012, 06:24 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
Fish tape or string like jklingel said.
Old 03-30-2012, 12:02 AM   #4
Originally Posted by Windows on Wash View Post
Fish tape....
Now you're getting all fancy on us!
romex connection to receptacle apshirm Electrical 3 09-15-2011 02:28 PM
A Couple of Questions About Running Romex Wire Near Utilities toobhed Electrical 4 08-26-2011 08:15 AM
Running ROMEX into Conduit tlj Electrical 15 11-05-2009 07:20 PM
Running romex along a wall in a closet Red Squirrel Electrical 16 10-02-2009 08:44 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
