Roxul Vs Guardian Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 06:41 AM   #1
Roxul vs Guardian Insulation?
I'm about to insulate my whole house and have to decide between using Guardian brand or Roxul brand insulation. Please share your experiences with each and help me choose. I have to decide Friday. Thanks!
psubaron is offline   Reply With Quote
Old 09-16-2011, 07:04 AM   #2
msaeger's Avatar
Rewards Points: 260
Do you have a source for either locally?
msaeger is offline   Reply With Quote
Old 09-16-2011, 07:08 AM   #3
Yes I can get either locally.
Roxul is stone wool that isn't faced which is my one concern. I plan to use a vapor barrier on external walls but had hoped to use Kraft faced insulation then a vapor barrier before drywall. Perhaps this is just my lack of knowledge ....is it just as good to used the roxul stone wool without a facing and just put plastic vapor barrior over it?
Which will give better insulation ...the stone wool or fiberglass? Roxul claims an R-23 and the guardian is r-19 for 2 x 6 channels.
Old 09-16-2011, 07:51 AM   #4
concretemasonry's Avatar
Rewards Points: 2,650
I would go with the Roxul since it is a better product.
I would just go with the Roxul and then apply a poly vapor barrier. If you are really that concerned about a vapor barrier, you could get a thicker (more mils) vapor barrier that will more resistant to holes and tears during construction.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Canucker (09-16-2011)
Old 09-29-2011, 10:31 AM   #5
I went with the Roxul r-23 for 2 x 6 exterior walls. It installs so easy and stays where you shove it. It fits between the joists snuggly. I recommend it!
roxul insulation ctkeebler Building & Construction 15 01-09-2016 05:54 PM
Is my Roxul sound insulation toxic? Brit Insulation 20 08-12-2012 09:13 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Radon in Roxul insulation? stretchonme Building & Construction 16 01-04-2012 07:52 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
