-   Insulation (http://www.diychatroom.com/f103/)
-   -   Roxul vs Guardian Insulation? (http://www.diychatroom.com/f103/roxul-vs-guardian-insulation-117380/)
psubaron 09-16-2011 06:41 AM
I'm about to insulate my whole house and have to decide between using Guardian brand or Roxul brand insulation. Please share your experiences with each and help me choose. I have to decide Friday. Thanks!
msaeger 09-16-2011 07:04 AM
Do you have a source for either locally?
psubaron 09-16-2011 07:08 AM
Yes I can get either locally.
Roxul is stone wool that isn't faced which is my one concern. I plan to use a vapor barrier on external walls but had hoped to use Kraft faced insulation then a vapor barrier before drywall. Perhaps this is just my lack of knowledge ....is it just as good to used the roxul stone wool without a facing and just put plastic vapor barrior over it?
Which will give better insulation ...the stone wool or fiberglass? Roxul claims an R-23 and the guardian is r-19 for 2 x 6 channels.
concretemasonry 09-16-2011 07:51 AM
I would go with the Roxul since it is a better product.
I would just go with the Roxul and then apply a poly vapor barrier. If you are really that concerned about a vapor barrier, you could get a thicker (more mils) vapor barrier that will more resistant to holes and tears during construction.
Dick
psubaron 09-29-2011 10:31 AM
I went with the Roxul r-23 for 2 x 6 exterior walls. It installs so easy and stays where you shove it. It fits between the joists snuggly. I recommend it!
