Roxul Insulation Packaging Size - Insulation - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 09:46 PM   #1
bryanp22's Avatar
Rewards Points: 294
Roxul insulation packaging size
How large are the roxul R15 batts in the packaging? Trying to figure out how big of truck I need to go get insulation. Anyone have one they can measure inside the packaging? I'm a ways from a lowes.
bryanp22 is offline   Reply With Quote
Old 08-27-2013, 08:14 PM   #2
Rewards Points: 236
yeah. brb
Fix'n it is offline   Reply With Quote
Old 08-27-2013, 08:18 PM   #3
Rewards Points: 236
14ish x 46ish x 26ish. this is R-23 comfort batt. but i noticed that the bags are the same size. i have this one, because i did not need to use it.
Old 08-28-2013, 07:11 AM   #4
Rewards Points: 2,638
The batt inside the packaging is 15.25 x 47 x 3.5 according to the Roxul web site.
If you are looking for the outside dimensions of the package, probably about 19-20" square x 48" That's the size of the R22 packages that I used, and my recollection is that the packages of different thicknesses looked the same size when I was looking at them in the store.
SPS-1 is offline   Reply With Quote
Radon in Roxul insulation? stretchonme Building & Construction 16 01-04-2012 07:52 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 07:03 AM
