Roofing Debris In Attic Insulation (cleanup) - Insulation - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 12:36 PM   #1
Question
Roofing debris in attic insulation (cleanup)
A recent roofing job (down to the sheathing) left a filthy mess of debris in my attic blown-in cellulose insulation. I was planning to remove as many fragments of roofing trash that fell through the slats as I can, and add a layer of R-30 unfaced fiberglass across the attic floor joists.
Should I expect a decrease in R value in the old insulation from the roofing debris/dust invasion, or will it be fine once it's been fluffed up again?
Thanks,
Steve
SteveL0530 is offline   Reply With Quote
Old 05-09-2011, 05:10 PM   #2
Registered User
Rewards Points: 5,256
Hard to fluff-up again. Why adding f.g. over cellulose, is it the weight; The "biggest loser" in fiberglass insulation....
Gary
Old 05-09-2011, 10:30 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You'd have a very difficult time digging debris out of loose fill cellulose. Believe me, I've lost flashlights, tape measures, etc while working in the stuff... The debris is unlikely to have much effect on the R-value, but if anything, blow on a little more cellulose and call it a day. FG batting over the top makes little sense, as does the impossible task of trying to fish out debris..
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Tags
cellulose insulation , cleanup , fiberglass insulation , roofing
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
attic insulation question justin76 General DIY Discussions 6 01-23-2008 02:28 PM
