Roof Venting Around Can Lights - Insulation - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 11:07 AM   #1
Roof venting around can lights
I have an addition on my house (12x15, 4 season room) that has a cathedral ceiling. I have installed can lights in a few of the rafter bays which will make installing roof baffles difficult. How important is it to vent every bay, and if I dont vent the few bays with cans in them, should I still hold the insulation off the roof sheathing by an inch? The cans are airtight IC cans. Thanks
123ozzie is offline   Reply With Quote
Old 11-29-2011, 07:44 PM   #2
Registered User
Rewards Points: 526
Every rafter bay requires venting. Where are you located?
Gary
Old 11-29-2011, 08:04 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,280
+1 on venting every bay.
We just stripped a roof that was a cathedral roof with can lights (not airtight) and the rot was most concentrated in the rafter bays that became obstructed (insulation batt falling down) and had the can lights.
Can lights, regardless of airtight or not, will be a big short circuit in the insulation layer and will be points of additional moisture because of the interruption in the vapor retarder and lower than average R-Value. Even if you don't think there is air leakage, there probably is.
You need to vent each bay.
venting my roof properly MLMIB Roofing/Siding 2 08-12-2010 07:14 AM
Roof Venting??? JoAnn Roofing/Siding 2 03-17-2010 09:42 AM
Proper venting of new roof on attached garage jlatulippe Roofing/Siding 1 11-26-2009 03:24 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Roof Venting Issue, crawlspace supton Roofing/Siding 1 11-12-2008 06:44 AM
