Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-30-2013, 11:00 AM   #1
Roof vent in Garage
Hello, I'm a new home owner and new to the forum. I'm not sure where to post this so move it if im In the wrong place. I've got a 2 stall garage attached with a roof vent. Heavy rain and snow with wind the roof vent leaks into my garage. Are roof vents in a garage really needed? I thought about throwing some insulation up there to at least cut the wind from blowing snow. What's the best way to weather proof a roof vent? I plan to finish it with drywall so I need to do something to cut the weather. Thanks
randen89sc is offline   Reply With Quote
Old 01-30-2013, 11:10 AM   #2
Roof vent in Garage
Without knowing where you live by adding it to your profile and letting us know what type vent you have now not sure how anyones going to be of much help.
The vent on the roof and the soffit vents are very important.
Done right it draws out the hot moist air, helps prevent ice dams, lengthen the life of the shingles and sheathing.
Old 01-30-2013, 11:22 AM   #3
Roof vent in Garage
Thanks for reply. I live in West Virginia. I will try And add a picture tonight if that would help.
Old 01-30-2013, 11:23 AM   #4
Windows & Remodeling
HomeSealed's Avatar
Roof vent in Garage
You may just want to look into replacing that vent, as it should not be letting water in . I can't comment on specifics, but generally you do not want to block that off.
HomeSealed is offline   Reply With Quote
Old 01-30-2013, 11:28 AM   #5
Roof vent in Garage
Sure it's not the way it was installed, or it's rusted out?
Old 01-30-2013, 11:38 AM   #6
Roof vent in Garage
Looks new, not rusted at all. I'm gonna try and get pictures
some frost on edges of roof sheeting in Attic above garage. Also am getting frost on roofing nails. Sebo20 Roofing 3 01-20-2013 10:36 AM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Deck on Garage roof billybarty Building & Construction 2 02-26-2008 05:33 PM
