Rim Joist Insulation Suprise - Insulation - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 06:33 PM   #1
Rim joist insulation suprise
While insulating my rim joists with 2" XSP i found this little gem, where part of my home extends past the foundation. No surprise this is also one of the coldest portion of flooring....
How do i go about tackling this void? It extends way beyond arms reach.
rjwrightohio is offline   Reply With Quote
Old 11-04-2011, 07:55 PM   #2
I can tie my own shoes
algored2deth's Avatar
Vacuum out all the loose material. Get yourself a can of spray foam. Find some clear tubing that fits over the spray foam stray that fits fairly snug. You might also need a guide wire, like an old hanger or similar. Tape the wire to the tube, connect the straw of spray foam to the tube, stick it in the hole and then spray and seal it up. Beforehand, you could also try and cut a piece of XPS and see if you can fit and spray foam it in. this is what I would do.
algored2deth is offline   Reply With Quote
Old 11-04-2011, 08:12 PM   #3
Registered User
Rewards Points: 5,514
That will work. If the soffit is easily replaced/re-installed, add rigid foam board to the joist bottoms also: http://www.buildingscience.com/docum...n-crawlspaces/
otherwise you will only be getting R-value of 1.25 per inch of solid wood-- 9" joist= R-11, plus the thermal break.
Gary
Old 11-05-2011, 09:54 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Seal and insulated that entire cavity.
Do you have access to a 2-part spray foam kit?
Old 11-06-2011, 09:58 AM   #5
Gary, fantastic link.. Once it warms up later this afternoon i plan to crawl under there and see what sort of access i have.
I do not presently have access to a two part foam solution. Your suggesting filling the entire void solid with spray foam?
Old 11-06-2011, 10:56 AM   #6
If you had it, yes. That would be the easiest application as it is not that deep or big of a void to fill.
insulation of rim joist sherryne Building & Construction 1 01-04-2011 12:12 PM
Floor joist insulation Arky217 Building & Construction 0 12-29-2010 11:56 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Rim Joist Insulation ja191992stg Building & Construction 53 03-22-2010 08:41 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
