Rim-joist Insulation - Spray Or Sheet Foam? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 08:43 AM   #16
Remodeling Contractor
Just a note.... in a basement the air flow moves both from the exterior to the interior in the summer and from the interior to the exterior in the winter. So a vapor barrier (spray foam top and bottom edges of rim joist prior to batt installation) will trap moisture in the winter. Thus.... no fiberglass!
Old 01-15-2012, 09:18 AM   #17
Rewards Points: 674
Thanks for the reply Bob.
Beepster is offline   Reply With Quote
Old 01-17-2012, 01:55 PM   #18
I was looking at doing this to my basement recently- good info here.
DIYWorker is offline   Reply With Quote
Old 01-17-2012, 04:38 PM   #19
Rewards Points: 2,638
I would not be so sure Option 2 is easier. I recently found air leaking where 4 inlet/ehaust pipes (water heater and furnace) ran through. The spray foam did not have enough adhesion and/or mechanical strength and would pull off just by gravity. (That never happens to Mike Holmes) I managed to get the job done by damming up the area to be insulated, but I would not look forward to doing a whole house like that.
OK, I used the house brand foam of a big box store. If you bought the PU foam in two tanks, that might be better stuff. But I would tend to agree with the fellows that suggested XPS foam boards.
SPS-1 is online now   Reply With Quote
Old 01-30-2012, 08:44 AM   #20
Rewards Points: 77
Originally Posted by Bob Mariani
Because any profession with building science knowledge will know that this will only trap moisture making the fiberglass ineffective and for mold to grow. Rim joists need to be air sealed and insulated to the same R-value your local codes require for the exterior walls. R19 in my area. Here is how I do rim joists http://www.homedoctorofamerica.com/rim-joists.
Your first solution (flash an batt works fine. Easy to use Roxul batt and spray foam. Or use polyicocyanurate foam board. Spray foam is much easier and is the only method I use.
Following this thread. Good info. One question, what if you have electric wires running in this area?
Mikenra is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 12:58 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
"effective" R-value for spray foam insulation? red86yota Building & Construction 1 04-23-2009 12:18 PM
